How To
How to: Fit towhooks to an '05+
This is a discussion on How to: Fit towhooks to an '05+ within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
Originally Posted by Hoosierjeeper I know...how did I screw up on this? So the M bolt/screw, I put it in ...
Like Tree1Likes
Old 12-29-2009, 03:38 PM   #1 (permalink)
jhblackwell's Avatar
So the M bolt/screw, I put it in the wrong way. No prob, just slide it through the way I put it in. Nope, fell over in the bumper. So now to get it, do I have to remove the bumper to get to it? If so, how shall I do that?
TIA.
You would have to on an '06. I assume an '05 would be similar. Actually, you remove the plastic bumper cover. Following is part of how I installed my front shackles with how you remove the grill and bumper, etc.
pop hood and release clips at top of front grill, starting at headlights
continue releasing clips along top of grille
lean grill top out to release lower clips and remove grill.
unscrew each turn signal lens.
pull assembly out of slot in fender cowling
remove bolt from fender cowling at headlight
remove bolt on bottom of cowling by bottom of radiator, each side
pry plastic pop rivet off at bottom, each side
pry pop rivet off at leading edge of front fender well lining
slide screw driver, etc., behind head of pop rivet and carefully pry out
release clip at top of cowling by wheel well
gently pull on turn signal harness rivet and remove from cowling
twist turn signal bulb socket and remove. cowling should drop off
front of KJ with plastic removed
remove all three nuts from tow hooks and remove
remove "w", or double bolt leaving spring clip nut in place
remove access hole cap
tow hook access hole ready to modify
Once you have the access hole cap off you can retrieve the "M" bolt. Hope this helps.
Chitownjohnny likes this.
jhblackwell is offline   Reply With Quote
Old 01-09-2010, 08:57 PM   #2 (permalink)
HoosierJeeper's Avatar
Nice write up...saved me!
15 KL Limited V6 4x4
07 LR3 SE V8
96 XJ Country
Old 01-10-2010, 09:40 PM   #3 (permalink)
twack's Avatar
Send a message via AIM to twack
Nice work can you throw up a pic of it all done
twack is offline   Reply With Quote
Old 01-11-2010, 08:04 AM   #4 (permalink)
07 LR3 SE V8
96 XJ Country
Old 02-03-2010, 10:31 PM   #5 (permalink)
Uncle Krusty's Avatar
Send a message via ICQ to Uncle Krusty
Love the write-up, and the pics were great - always worth a thousand words... Especially the last one of the whole thing re-assembled.
My only question is why you didn't cut out the areas around the hooks for better access? I don't mean to be critical, as I may have a problem chopping into mine some day as well, but the cut-out areas are clearly defined in the bumper, and I think with it off even I could follow the lines... Id tape them up first to protect the finish, but some carefull work with even a hacksaw would be all that is needed.
UK
2006 Liberty Limited 4x4
2" of OME / Rancho Lift
Wrangler Rubicon wheels (Moabs)
245/75-16 Goodyear Wrangler MT/R
Uncle Krusty is offline   Reply With Quote
Old 05-26-2010, 01:24 PM   #6 (permalink)
willy88's Avatar
thank gawd this was here. was about to cut a hole through my bumper to fit my hooks! haha
willy88 is offline   Reply With Quote
Old 05-26-2010, 04:48 PM   #7 (permalink)
A few more pics during the installation:
07 LR3 SE V8
96 XJ Country
Old 05-26-2010, 04:51 PM   #8 (permalink)
JeepINgeek's Avatar
Silver Supporter
Send a message via AIM to JeepINgeek Send a message via MSN to JeepINgeek Send a message via Yahoo to JeepINgeek Send a message via Skype™ to JeepINgeek
dude?! why?1 i did mine with the bumper on lmao
just gota take yoru time... oh well
Black 06 Special Edition
Mechanica Wheels, Graphite Fenders and Bumpers, Hooked, Armored, OME/Rancho, Boiler Shims, Flowmaster 50
JeepINgeek is offline   Reply With Quote
Old 05-26-2010, 05:03 PM   #9 (permalink)
eyehatetofu's Avatar
JPOTM WINNER
Originally Posted by HoosierJeeper View Post
I like how HJ has a fancy shoe polisher in his garage. Not only does his KJ need to be spotless, but apparently his shoes do as well
Originally Posted by ridenby View Post
Do not give a hoot in hell about global warming,whales,or goose stepping spainish nazi's.
eyehatetofu is offline   Reply With Quote
Old 05-26-2010, 05:22 PM   #10 (permalink)
Banned
mag03kj is offline   Reply With Quote
