jeepkj02
Time Needed: 30-45 minutes
Items Needed:
Steps:
Items Needed:
- Turkey Baster
- 2 quarts of Power Steering Fluid or ATF+4 (check your owner's manual)
Steps:
- Remove power steering cap and remove as much fluid as you can with the turkey baster.
- Pour in new fluid into the power steering reservoir and screw cap back on and start engine. Turn the steering wheel lock-to-lock for a few minutes. (About 10-15 times) Do not stop between turns.
- Turn engine off.
- Repeat Step 2 and 3 until you finish the first quart. This is to get as much of the old fluid out.
- Finally, pour in your fluid one last time until it reaches the "hot" line on the power steering reservoir.
- Your finished. Repeat every 7,500-10,000 miles.
