How To
HOW TO: Change Transfer Case Position Switch
This is a discussion on HOW TO: Change Transfer Case Position Switch within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
2004 Liberty 3.7L Part number 5083138AA Cost of switch from dealer $72.00 Special tools - 1-1/2" Socket- $19.99 3/4 to ...
Like Tree53Likes
Old 03-22-2010, 06:23 PM   #1 (permalink)
Downtown's Avatar
Send a message via MSN to Downtown
Default HOW TO: Change Transfer Case Position Switch
2004 Liberty 3.7L
Special tools -
3/4 to 1/2 drive adapter - $6.99
1/2" drive extension, 12" long - $? I had one in the toolbox
Remove center console
Remove the 4 nuts holding down the T-Case shift lever.
Note: The shift lever is attached to the t-case via a control cable.
There it is just waiting for you!!
Note: Dirt sitting on top of your t-case can fall into the sensor hole when removed. Now is the time to brush it or blow it off.
Remove the connector.
jp7794, fmurphy34, kidjedi and 6 others like this.
Downtown is offline   Reply With Quote
Old 03-22-2010, 06:29 PM   #2 (permalink)
Downtown's Avatar
Get the tool on there and give it a heave.
Warning: When the sensor busted loose, The wrench(and my knuckles) hit the gear indicator bezel and it busted into 20 pieces. Be careful!!
Swap the o-ring from the old to the new...
Doesn't seem wise to me but, the new one didn't have one.
Install new sensor...
Re-assemble...
Old 03-22-2010, 06:49 PM   #3 (permalink)
jnaut's Avatar
Dude, spread this how-to far and wide. I asked about this and researched it and while everyone said you could do it, the instructions were vague and indicated that you had to 'reach up above it' from under the vehicle.
Thanks and congrats.
-=Stock, but goin' places=-
04 3.7L Sport.
Auto Trans
Yokohama Geolandar AT/S 235/70/R16
Electronics: Garmin nuVi 265t GPS/ScanGauge II/Cobra 1500 watt (3000 peak) Inverter
Mileage trend:
I'm doing God's work...because he's too f*@$%ing lazy to do it himself.
jnaut is offline   Reply With Quote
Old 03-22-2010, 07:40 PM   #4 (permalink)
Downtown's Avatar
Thanks!
I did the same research and I agree...
Also, some of the things out there we not quite truthful (for replacement on 2004 KJ)
1. IMO - imposssible to reach 'reach up above it' from under the vehicle (with any useful tool that could remove it... I tried)
2. NOT a 10 minute job (give youself 1hr to 2hrs (4-12 beers ))
3. It's NOT a $20 part - I looked far and wide and the only 2 places that had it was the dealer by my house ($96.00) and the dealer by my work ($72.00) - Minneapolis/St. Paul Metro area
Old 03-23-2010, 02:44 AM   #5 (permalink)
jnaut's Avatar
Originally Posted by Downtown View Post
Thanks!
Word, when mine failed (before it mysteriously fixed itself) I reached up there and sure, I could feel it up there, but dang if I could have gotten it out. Now I know if it breaks again... and of course doesn't mysteriously fix itself, I can swap it out.
04 3.7L Sport.
Auto Trans
Mileage trend:
Old 03-23-2010, 01:53 PM   #6 (permalink)
I suppose you've been seing the part-time light in the dash even though the 4x4 shifter is down?
Thanks for the write up.
meh_kick is offline   Reply With Quote
Old 03-23-2010, 03:03 PM   #7 (permalink)
Downtown's Avatar
Yes that is correct...
The t-case would be in 2HI with the "PART TIME" light on
And, when in 4HI the "PART TIME" light would be off
4LO worked fine
nohitter64 likes this.
Old 03-23-2010, 05:04 PM   #8 (permalink)
sevenhelmet's Avatar
It looks like a simple push button toggle switch. Mine is obviously switching since the light goes on and off with the lever, just the opposite way. What about taking the switch out and pressing it once with your finger to "un-flip" it so it will indicate correctly? Is that a possibility, or does the switch absolutely have to be changed?
Also, should the 4LO light be on with the transfer case lever in neutral?
2005 Nissan XTerra S with 32" Maxxis Mudders, rock sliders, On-Board Air with Air Horn, Cobra CB, 2m/70cm HAM radio, Jerry Can roof rack, (more mods coming)
SOLD: 2003 KJ 5-speed Sport 4x4, OME lifted, Soft 8s, EVIC, Cobra 75WXST
sevenhelmet is offline   Reply With Quote
Old 03-23-2010, 05:34 PM   #9 (permalink)
Downtown's Avatar
I found this -
"The sensor consists of a five position, resistive multiplexed circuit which returns a specific resistance value to the Powertrain Control Module (PCM) for each transfer case operating mode." - http://townhall.edmunds.com/direct/view/.f19a95d
What this means is: The PCM measures how far the plunger has been pushed in and looks for 5 different values (positions).
So... No, you won't be able to 'un-flip' it - Think of it more like a sensor
Using the term "switch" is a little misleading... But, that's what the dealer called it.
I think that something conductive got past the seals in the switch/sensor.
Also, I am pretty sure you shouldn't see "4LO" on your cluster when in t-case neutral. This, IMO, is just another symptom of a bad t-case position switch/sensor
Old 03-23-2010, 07:39 PM   #10 (permalink)
That makes sense- if it's one position "off", then the light would go out in 4HI because the switch "thinks" it's actually in neutral.
Looks like I might have to buy the replacement after all.
