BluPhant
REMOVAL
(1) Disconnect and isolate the battery negative cable.
(2) Reach behind the headlamp unit from the engine compartment side of the upper radiator crossmember to access the headlamp bulb lock ring (Fig.23).
(3) Firmly grasp the lock ring on the back of the headlamp unit housing.
(4) Rotate the lock ring on the back of the headlamp unit housing counterclockwise about 30 degrees.
CAUTION: Do not contaminate the bulb glass by touching it with your fingers or by allowing it to contact other oily surfaces. Shortened bulb life will result.
(5) Pull the lock ring, socket, and bulb straight out of the headlamp unit housing and up from behind the upper radiator crossmember (Fig. 24).
(6) Disconnect the grille opening reinforcement wire harness connector for the headlamp bulb from the connector receptacle on the bulb socket.
(7) Remove the bulb and bulb socket from the lock ring as a unit.
INSTALLATION
CAUTION: Always use the correct bulb size and type for replacement. An incorrect bulb size or type may overheat and cause damage to the lamp, the socket and/or the lamp wiring.
(1) Position the headlamp bulb and socket unit into the lock ring (Fig. 24).
(2) Reconnect the grille opening reinforcement wire harness connector for the headlamp bulb to the connector receptacle on the bulb socket.
(3) Position the lock ring, socket, and bulb down behind the upper radiator crossmember and align them with the socket opening on the back of the headlamp unit housing.
(4) Push the socket and bulb straight into the headlamp unit housing until they are firmly seated.
(5) Position the lock ring over the socket and engage it with the flange on the back of the headlamp unit housing (Fig. 23).
(6) Rotate the lock ring on the back of the headlamp unit housing clockwise about 30 degrees.
(7) Reconnect the battery negative cable.
INSTALLATION
