How To
Failed compression test
This is a discussion on Failed compression test within the How To forums, part of the Jeep Liberty - KJ (02 to 07) category!
Okay so my girlfriend bought a 2002 Jeep liberty from a dealership back in March. Last week it wouldn't start. ...
Like Tree3Likes
Old 06-18-2015, 11:40 AM   #1 (permalink)
Default Failed compression test
Okay so my girlfriend bought a 2002 Jeep liberty from a dealership back in March. Last week it wouldn't start. After I replaced the spark plugs it started but was idling poorly. I decided to have it towed to a shop. They did a compression test and cylinder 2 has 0 compression. They pretty much told me I was probably going to need a new motor. I'm gonna have it towed back here so I can work on it myself. Is there any chance of saving it? I already have a $300 shop bill for the little bit of testing that they did.
Dannyboy745 is offline   Reply With Quote
Old 06-18-2015, 11:45 AM   #2 (permalink)
dude1116's Avatar
Dropped a valve seat probably??
'04 Silver KJ
-OME927 springs/90009 shocks, 3/8 inches of top plate, conduits, and JBA UCAs in the front. JBA 4" springs/Monroe Load Levelers in the rear.
-LT265/70/16 Hankook Dynapro ATM, Load Range D2
-Magnaflow Muffler
-Sport 4x4 Hood Decal, Graphite Jeep Hood Emblem (Woo!)
-Altezza Tail Lights, all LED bulbs and load resistors, LED third tail light
-IRO UCA w/ Iron Forge Customs bracket
dude1116 is offline   Reply With Quote
Old 06-18-2015, 12:01 PM   #3 (permalink)
Jbergun's Avatar
Isnt there some kind of lemon clause on that you bought this thing from a dealership less than 4months ago
2002 Liberty Limited (Silver)
235-70-16 General Grabber At2
Mopat Plastic Brush Guard (Body Color)
Borla CatBack Dual Exit(Engine Enamel Gloss Black)
Custom Paint Rims(gunmetal), Undercarriage(Black SS), Grill Plastic Thing(Black)
Cargo Shelf
Jensen VX4012
JBL cs1214 sub, 751ez amp(Pending)
OME 927/948 Bilstein Shocks "Just Lifted"
But past that stock.
Jbergun is offline   Reply With Quote
Old 06-18-2015, 12:06 PM   #4 (permalink)
Seal or seat? I know what the valve seal is. Do you have a diagram of what where exactly the valve seat sits?
Old 06-18-2015, 12:11 PM   #5 (permalink)
She bought it as is with no warranty so I really don't know
Old 06-18-2015, 02:00 PM   #6 (permalink)
dropped a valve it happens on them eventually ... just like the rad leak ... and the saggy front suspension .... you either need a new motor or get the whole top end done.
2004 3.7 42rle NV231J 130k miles
ftaa is offline   Reply With Quote
Old 06-18-2015, 02:05 PM   #7 (permalink)
CactusJacked's Avatar
That was my first thought too. In layman's terms, the seat is a hardened ring pressed into the head that the valve sits down to. They have a tendency to work loose and "drop", which could wedge the valve open. A stuck open valve will give you zero compression. Even a terribly worn engine has some sort of compression, unless the cylinder wall is blown out. Ask them if they have a scope where they can go in through the spark plug hole for an exploratory. I think they're jumping the gun trying to tell you you need a whole new engine.
profdlp likes this.
02 Renegade, 5-speed manual.
265/75R16 BF Goodrich Rugged Terrain.
OME/Frankenlift, OME shocks. JBA cut CV axles.
Those who think they know everything are especially annoying to those of us who actually do.
CactusJacked is offline   Reply With Quote
Old 06-18-2015, 02:32 PM   #8 (permalink)
agreed on the whole new engine.. but at least while in there may as well do the whole top end ... if funds are an issue a new to him motor may be in order .
Old 06-18-2015, 06:34 PM   #9 (permalink)
I got the jeep back from the shop. I'm going to pull the heads off myself and check out the damage. Trying to cut down on the cost of fixing it since we just got it. It the heads are bad I will the them machined. I got the time so I'm hoping I can do this myself. Any tips are greatly appreciated.
Old 06-18-2015, 08:20 PM   #10 (permalink)
its not the heads its the sleve that the valves sit in ... heads will be fine. its the valve train you will need to replace. they have a habbit on some to come loose drop down and cause the valve to be stuck open giving no compression the other thing could be a lifter off under the rocker cover you will need a lash adjuster to fix that the plastic rockers can come loose. ..... thats the minor problem they normally fall off because of the dropped valve and thats the sleeve ..
