Go Back   Jeep Liberty Forum - JeepKJ Country > Jeep Liberty - KJ (02 to 07) > Tires / Wheels
Tires / Wheels
What's a good automatic tire deflator?
This is a discussion on What's a good automatic tire deflator? within the Tires / Wheels forums, part of the Jeep Liberty - KJ (02 to 07) category!
These? http://trailheaddeflators.com/product.htm A link to a B.C. 4X4 parts supplier. http://www.rovingrecovery.com/deflators.htm Or... Staun Tire deflators? http://www.staunproducts.com/benefits.php I always just use ...
Questions about wheels and tires.
Old 12-21-2009, 04:18 AM   #1 (permalink)
Banned
Location: Slightly North of the 49 th. Parallel... In HongCouver
Default What's a good automatic tire deflator?
These?
Or...
I always just use a tire valve remover or depress the
tire valve with a small Phillips screw driver...
Buy that's always a pain in the arse and hit and miss
as far as getting the air pressures the same for all four
tires.
Ry' N Jen is offline   Reply With Quote
Old 12-21-2009, 06:49 AM   #2 (permalink)
Those screw on things dont work right
the best one I have seen in the on Currie makes
IIRC it is called the easy tire deflator or some thing
basically it screws on the valve stem
you use it to remove the core
then deflate the tire
it has a gauge so you can see where you are at
J-Thompson is offline   Reply With Quote
Old 12-22-2009, 01:07 AM   #3 (permalink)
Uncle Krusty's Avatar
Send a message via ICQ to Uncle Krusty
I was going to say "a nail", but if you're just looking to air down some, that's another story...
As far as getting all 4 the same, I've seen "Tee" hoses used with the ends for the valve stems that clamp on like an inflator With the tee hose installed on both front tires, you deflate them at the same time. Closing the outlet lets the two tires balance preasure-wise.
I've been meaning to build me one, even bought the 1/4" hose to do so. The idea is to use it when inflating the tires to balance the side-to-side for more even tire wear / handeling.
UK
2006 Liberty Limited 4x4
2" of OME / Rancho Lift
Wrangler Rubicon wheels (Moabs)
245/75-16 Goodyear Wrangler MT/R
Uncle Krusty is offline   Reply With Quote
Old 12-22-2009, 02:57 AM   #4 (permalink)
KeswickDave's Avatar
Gold Moderator
Yeah I was going to say one of these...
But if you want to fill 'em up again, I'm not so sure
Interesting idea with the T hose Uncle Krusty...
05 Black KJ Sport
Click here to become a supporting member
KeswickDave is offline   Reply With Quote
Old 12-22-2009, 03:27 AM   #5 (permalink)
Banned
I've seen one guy who had a hose connected to all four tires at once so when he airs down they all ballance out at the same time.
Old 12-22-2009, 09:14 AM   #6 (permalink)
Reminds me I got one of those in some other Jeep stuff I bought last year! Works to air down or air back up! Never tried it but it would seem to be OK
MUDD'S MOTORSPORTS
I DO IFS LIFT INSTALLS
04 Kilimanjaro Edition
05 Limited/stock for now
tommudd is online now   Reply With Quote
Old 02-07-2010, 10:36 AM   #7 (permalink)
Maybe have a look at the ARB unit.
It deflates quickly and is a gauge too.
That's my preferred one.
Cheers
Auberon
Auberon is offline   Reply With Quote
Old 02-08-2010, 10:37 PM   #8 (permalink)
Banned
Cheers
Auberon
Yup, gonna look at those closely AJ!
Old 09-18-2018, 04:18 AM   #9 (permalink)
Ristta's Avatar
I apologize for bumping...just my two cents...
I've used several different automatic tire deflators and none produced consistent enough air pressures for me to trust. I even made an 'octopus' rig that allowed me to deflate all four tires at once, that's what is in the photo below. Then I just used screw-on deflators that let the air out until you removed them. The common problem with all of those was that they were all SLOW because none removed the tire's valve core. They just pushed on the valve core's stem which doesn't let the air out very fast at all.
Then a few buddies on the trail who were standing around waiting for me to finish airing down showed me their ARB & Currie deflators (both are the same product) that have a slick way of unscrewing/completely removing the tire valve core and holding it inside (so it doesn't shoot out and get lost) while airing down. It really dumps the air out FAST. That was probably 15 years ago, I'll never switch away from this type of deflator. It lets me go from 24-26 psi to 4-8 psi in under 5 minutes total for all four tires...under a minute for each tire.
The time difference to get an entire group rolling on the trail when some are using deflators that just push the stem down can be enough that we run over to those slower wheelers to help them get aired down with our Currie/ARB deflators https://wheelstips.com/best-tire-inflator so we can get moving.On Youtube, there are a lot of interesting videos on this subject. I will leave one of them here, I hope someone will help in the future. Good Luck.
https://www.youtube.com/watch?v=6kul4YMcVpU
Ristta is offline   Reply With Quote
Old 09-18-2018, 08:14 AM   #10 (permalink)
Myke's Avatar
Can confirm those are very quick. Im over the screw on deflates. Not because they don't work but because I usually goto different pressures depending on what I'm doing.
If I'm doing difficult steep Rocky hill climbs I'll go down to 12psi but if we're cruising around the trails and hitting mud I'll stay up around 18-20psi and I don't want to carry two sets.
DobermanRacing.com - Jeep Liberty KJ/KK lower rear control arms now for sale! Fully rebuildable, adjustable, greasable, and nearly indestructible.
  • '98 XJ Sport - 6" Full-Traction 4-Link Long Arm w/ 37" Cooper STT PROs
Myke is offline   Reply With Quote
