I have a 04KJ and recently purchased a 3" Rough country lift... A friend has some 15" 10.5"w with a 3" offset wheels i want to purchase but have no clue what tire size i should be looking for? Please help
You're not really serious are you?
OK here is the real truth
first forget the spacer lift, 99% of the KJs are already sagged 3/4 to an inch
( to check measure in front, middle of the wheel to bottom of the flare, your 04 would of been 19 inches new )
installing a spacer lift " may " get you 1-1.5 inches, ...maybe
PLUS your suspension is worn out so a spacer lift will ride like crap and not handle at all well
Third , wheel size, 10 inches is way too wide, plus 3 inches of backspacing, you'll never be able to get out of the garage
and another thing there is no tire that we can run that will fit on a wheel like that .
NOW, full spring lift is the best and only real way to go
wheels, either 7 inches wide with 4 inches of backspacing or 8 inches wide and 5 inches of backspacing
The 8 inch wide there is only a couple of tires that will fit right so stay at 7 inches
NOW on fakebook they may tell sure it'll be fine, but then sit back and laugh at ya.
Here we'll tell you the truth and try to make sure you actually have something to drive in the end instead of a lawn ornament .
