Jeep Liberty Forum - JeepKJ Country
Jeep Liberty Forum - JeepKJ Country (http://www.jeepkj.com/forum/)
-   KJ General Discussion (http://www.jeepkj.com/forum/f196/)
-   -   yellow sludge in oil fill cap (http://www.jeepkj.com/forum/f196/yellow-sludge-oil-fill-cap-30936/)
b2 01-18-2007 08:04 PM
i just did my second oil change in my 06 KJ(6,300 miles on it). when i opened my oil fill cap i saw some yellow sludge in the tube, and some yellow/orange bubbles on the bottom of the cap. the rest of the oil that came out of the oil pan was fine(no colors/sludge). both changes that i have done have been with Mobil 1 full synthetic. anyone had any similar experiences. im hoping that those bubbles dont mean that i have coolant in my oil. thanks for your help,
dnm45227 01-18-2007 08:11 PM
not sure if it's the case in this instance, but it could be condensation. i've seen it before on others vehicles (maybe even our old '02 kj) we've owned. either way, i was always told not to worry about it.
Marlon_JB2 01-18-2007 08:23 PM
Condensation. Don't worry about it...
I've been told that it comes from taking lots of short trips. Well that was my case...
Eddo 01-18-2007 08:39 PM
Condensation mixed with oil. You will see it if you live in a humid climate and take lots of short trips. Had it happen to me. Seen it on other cars.
2003KJ 01-18-2007 08:43 PM
Condensation, however I would be slightly worried. Condensation that forms in the oil needs to be burned off, and this happens by the engine getting up to temperature, and the engine oil getting good and hot. If not, over time, the condensation will start to form sludge inside your engine...and that's not good. However, running Synthetic helps to cut back on the ammount of sludge that forms.
Short trips, where the engine either does not, or just barely gets completely warmed up are what causes this. Thats why I usually make it a point to drive around the block if I know i'm making a real short trip. I'd rather spend the extra in gas now then later on down the line have issues with that crap inside my engine.
cowdogg 01-18-2007 08:45 PM
It's condensation, don't worry about it. (whistle)
Dave 01-19-2007 12:58 AM
Quote:
That's funny as I do the same thing or combine a couple of errands into one longer trip. I change my own oil and have never noticed any condensation.
Ever notice if you change your own oil that when you take the oil filler cap off there is a removable splash guard in the filler neck. I check that too and it's always clean.
rxraptor02 01-28-2007 12:28 PM
I noticed the sludge buildup on my oild cap/pulg thing last night when I went through the local quick stop oil change place.
I know it is Condensation however I do not make any short trips. I only have 12,200 miles on my Liberty.
The humidity is not that high right now, so is there any other explination as to why this is happening?
Dave 01-28-2007 12:57 PM
I wonder what kind of oil they use??? I have been using Mobil 1 and havn't had that problem. Could it be the brand or type (synthetic - verses dino) of oil that makes a difference????
I don't know, just thinking out loud here.
Marlon_JB2 01-28-2007 01:03 PM
I've heard that synthetic or dino... doesn't matter, the issue still occurs.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Search Engine Optimization by vBSEO
Ad Management by RedTyger
