Why did I have to charge the battery?
This is a discussion on Why did I have to charge the battery? within the KJ General Discussion forums, part of the Jeep Liberty - KJ (02 to 07) category!
05 Liberty Sport with fairly new battery. Noticed slow cranking over a few weeks. Decided to charge the battery. Charger ...
Like Tree7Likes
Old 12-03-2018, 06:02 PM   #1 (permalink)
Default Why did I have to charge the battery?
05 Liberty Sport with fairly new battery. Noticed slow cranking over a few weeks. Decided to charge the battery. Charger showed only 50% battery charge. Appears alternator may not be putting out but idiot light not glowing. Battery charged up fine. Any ideas anyone?
Black Bob is offline   Reply With Quote
Old 12-03-2018, 07:13 PM   #2 (permalink)
tjkj2002's Avatar
Stock spec battery you may have a issue but if it has more CCA's then stock the stock system will not fully charge it and it will require a actual charger to fully charge it every few months.
LibertyTC likes this.
Old 12-04-2018, 02:34 AM   #3 (permalink)
What charging voltage are you getting over the battery when running?
Should be about 13.4 volts.
Make sure all the battery and all large engine grounding straps are clean and tight.
You may have a current drain on the battery when standing switched off overnight.
You need to put a meter...set on AMPS....in series with the battery.
Do not start the engine or you will blow a fuse inside the meter.
Current drawn should be not much higher that about 30 milli Amps ie. 0.030 Amps.
If it is much higher you need to pull fuses out one by one to see which circuit is causing the drain.
Billwill is offline   Reply With Quote
Old 12-04-2018, 05:59 AM   #4 (permalink)
LibertyTC's Avatar
What battery do you have & what CCA is it listing? Use a Voltage ohm meter and with Jeep running tells us what the volts reading is.
You need good amps & voltage output to keep the battery charged up & have it run for 30+ minutes per day.
After sitting overnight a good reading should be over 12.4 volts unless there is a drain somewhere or a weak battery. This is where a load test is also a good idea.
My ALT shows around 14.5v fired up first thing in the AM no real draw- No lights, or blower motor on etc.
When below freezing you have less cranking power- This chart explains much.
Having an 800CCA + AGM battery is a real advantage come winter time.
JasonJ likes this.
Need A Push?
LibertyTC is offline   Reply With Quote
Old 12-04-2018, 03:03 PM   #5 (permalink)
Man, thats a lot of technical stuff. I'll see if I can figure this out. My brain is old and I'm not too electrically inclined.
It's an Exide group 34 saying CCA at 0 deg.F 630 CA at 32 deg F 785. I have a cheap meter but don't know how to use it much. Mostly test AAA batteries and what not. It's a Harbor Freight Cen-Tech. Should the car be running? How do I hook up the leads? Thank you all for the help.
Old 12-04-2018, 03:32 PM   #6 (permalink)
Looks like I'm getting 14.7 if I did everything correctly and had the car running. BTW, the KJ sit a lot and only has 72K on the clock. Really not sure how old the battery is. Thought it was only a couple years old but could be wrong about that. Thanks for the good will.
Old 12-04-2018, 04:08 PM   #7 (permalink)
LibertyTC's Avatar
14.7 is good output voltage so it's charging probably ok.
Lead acid batteries tend to last 3-5 years, and trickle charging them especially if a vehicle sits is always good to keep them topped up.
I would recommend charging the battery overnight @ 3-6 amp setting & then take it into a shop for a battery load test, that will confirm the available CCA = pass or fail.
Many do not charge for a load test.
Automatic intelligent chargers are handy & I use the C-Tek which does a great job for keeping my battery up to speed.
Which battery charger are you using?
Need A Push?
Old 12-04-2018, 09:06 PM   #8 (permalink)
Walmart, Schumacher I believe.
Old 12-05-2018, 03:24 PM   #9 (permalink)
Schumacher is decent stuff, I've never had an issue using them before. As long as it is set correctly to your battery type (deep cycle or not, amp settings, et al) you should be fine with that.
Old 12-06-2018, 03:45 AM   #10 (permalink)
turblediesel's Avatar
Might be a "letter-number" dot stuck to your battery, top or sides. Letter is month manufactured, number is year. Same code might be melted into the side lip of the plastic top of the battery.
turblediesel is offline   Reply With Quote
