Tow hook help...
I know...how did I screw up on this?:eek:
So the M bolt/screw, I put it in the wrong way. No prob, just slide it through the way I put it in. Nope, fell over in the bumper. So now to get it, do I have to remove the bumper to get to it? If so, how shall I do that?
TIA.
jhblackwell
Athens, GA.
TIA.
You would have to on an '06. I assume an '05 would be similar. Actually, you remove the plastic bumper cover. Following is part of how I installed my front shackles with how you remove the grill and bumper, etc.
pop hood and release clips at top of front grill, starting at headlights
continue releasing clips along top of grille
lean grill top out to release lower clips and remove grill.
unscrew each turn signal lens.
pull assembly out of slot in fender cowling
remove bolt from fender cowling at headlight
remove bolt on bottom of cowling by bottom of radiator, each side
pry plastic pop rivet off at bottom, each side
pry pop rivet off at leading edge of front fender well lining
slide screw driver, etc., behind head of pop rivet and carefully pry out
release clip at top of cowling by wheel well
gently pull on turn signal harness rivet and remove from cowling
twist turn signal bulb socket and remove. cowling should drop off
front of KJ with plastic removed
remove all three nuts from tow hooks and remove
remove "w", or double bolt leaving spring clip nut in place
remove access hole cap
tow hook access hole ready to modify
Once you have the access hole cap off you can retrieve the "M" bolt. Hope this helps.
m_volyrakis
Greece
Bravo jhblackwell! Nice work! I was under the impression that the bumper cover was held by revets that had to be broken in order to remove it. I'll be ussing this info to remove the cove and make some measuremens....;)
Thanks alot!
67Customs
North Carolina
The pre-'05s are.
Now, I was under the impression that you didn't need to remove the bumper to install the accessory tow hooks purchased from Mopar, right?
You are just needing to know how to remove the bumper to find the dropped piece, correct?
I just receved mine for Chirstmas. Just making sure.lol
Also, how did you remove the "knockouts" on the Limited bumper where the tow hooks go? I have several ways of doing it. just wondering how you did.
Lastly, you can remove the "Looking for front tow hooks" line in your sig now. :)
You don't have to do the knock outs. I'm not, for now at least. I'll change my sig soon...
kb0nly
Planet Earth
If your careful with those pop out rivets they are re-usable... If you break one hit a Napa store they got them in bags of 25 or you can buy a few...
67Customs
North Carolina
Are the rivets reuseable?
According to the FSM, you pop them out and then put them back in. Since it doesn't say anything about adding new ones, I would think that means they are reusable. And in my own personal opinion and experience, they look like reusable pop rivets.
They are...only broke one clip, the one of the fender flare...
jhblackwell
Athens, GA.
Thank you so much...that's what I needed. Thanks again! :)
Took me awhile to get back to this thread, but you're welcome.
This site and the L.O.S.T. site are excellent resources. Thanks to everyone that has posted mods, installs, etc. I'd be lost without the info.
Vranes17
New York
how the %@^*(&^%# F#$& do you get these tow hooks on. I got the M bolt in right but i cant get the nut on the bolt, theres absolutely no room. I tried taking the bumper off and i got the Grill off and starting on the bumper but I dont know how. Mines an 02 any help would be really appreciated.. my trucks in the garage apart and i wanna get it back together to go out.
Did you take the end caps off the frame?
Is the nut cross threading?
