Steel Front Diff
bugnout
Illinois
Changing out my stock Aluminum diff with JBA's new Steel D30. This one's built with 4.10's and an ARB air locker.
autoboy454
MASS
is it just me, or should the fillport on that diffy be up higher... If it is a steel diff modeled after the D30A (we'll call it the D30S :D ) then isn't the fill level (bottom of fillhole) higher so that the passenger axletube has some gear lube in it to lubricate the outmost bearing in there?
Just an observation from a passerby...
autoboy454
MASS
The new fill is at the same height as the original fill hole (on the right). This is the center section from a D30S.
Thats kinda my point exactly. I'm pretty sure the fluid fill levels are different for the D30A you find in all KJ's compared to a Dana 30 front axle found in Jeep YJ/TJ/XJ/...and the list goes on and on and on... lol.
bugnout
Illinois
Not quite getting your point. are you saying the the fluid level for a straight axle d30 not adequate if its re-purposed? The intermediate axle comes in at the same level as the full axle. The axle tube is exactly the same, just shorter. If the bearings were adequately lubed 2 ft farther out why wouldn't they be adequately lubed if they are little closer?
You will drive.gif in strong style now!
ThunderbirdJunkie
Bronze Supporter
Newport, KY
On one hand...2200 for a custom steel diff housing, ARB or OX locker installed, all ya gotta do is put it together...
On the other hand...
That's 11 used aluminum front diffs.
TBJ, I think this unit came assembled with gears and Arb Air locker, $3200+ shipping aprox.
I want to hear how it perform$.
bugnout
Illinois
Its in! drives great, smooth and quiet. Now need to put some break-in miles on it.
Auberon
Sydney, Australia
VERRRY COOL!:cool:
=P~
I saw the thing on their site and wondered how many more trillion bucks it wud add to get it across the Pacific to Australia.
Oh well----I can dream.
Cheers
Auberon
