nogoldformarfa
I have an 07 limited. I had a trailer hitch and harness installed a year ago. Out of the blue my reverse lights do not function. When I say reverse lights I am referring to the very bottom bulb.
I checked the connections and the only weird thing I could find was that the fuse was blown on the wire running from the trailer harness to the battery.
I replaced this fuse but it blows every time I connect it back to the battery. All other lights work so I am a bit confused at this point as to what the issue is.
Its almost like the reverse lights are grounded badly but I would think all of the lights in the tail use the same ground?
Any ideas?
Any ideas?
