j-rod
ok so I got to replace the busted mirror in the wifes KJ tonight.
I am getting conflicting info on removal of said door panel.
AAP guy said it just slides up, no push fasteners in the new vehicle.
most jeep sites say:
I was going to buy the removal tool today but the aap guy changed my mind. so should I go buy the tool or forgo it and use something else?
From the 2003 Liberty Service Manual
TRIM PANEL
REMOVAL
(1) Remove the inside handle screw plug and
remove the screw. (Fig. 9)
(2) Remove the pull handle screw.
(3) Using a trim stick C-4755 or equivalent, disengage
the trim panel clips and remove the trim panel.
(4) Disconnect the electrical connectors and the
inside handle actuator rod. (Fig. 10)
INSTALLATION
(1) Connect the inside handle actuator rod and the
electrical connectors.
(2) Position the trim panel and seat the clips fully.
(3) Instal the screws and install the screw plug.
