rsscoggins
All
I have to replace the high pressure line on the Liberty that we acquired for my son.
It is a 2002 and still has the original power steering Fluid in it (maybe not the "orginal" fluid since the hose has been replaced once before but you know what I mean - it has power steering fluid in it). I found a TSB that states that you can switch to ATF IF (big IF) you completely flush the system.
My question is since we are replacing the line, does it make sense to convert over to ATF or should we just stay with normal PS fluid?
AND if it makes since to convert, how do I completely flush the system during the conversion to ATF?
