P0139 code
fernandomvy
Australia
Whats up jeep lovers!
My engine light lit today. P0139
The car when im stop at trafic lights sometimes go a little rough. But comes back. I knew that could be some sparks or fuel injector issue.
Is there anyway to fix before take to the the mechanic? Injectors cleaners for example? Or this things doesnt work. Change plugs first?
Tks !!
That's a slow bank 1 downstream O2 sensor code. Best to get it someplace where they can watch the voltages as its running. Is this a OE sensor? Sometimes the aftermarket ones like Bosch are a bit slow and don't work well on these 3.7s.
benherr
CO
I second this advice. I had the same code, replaced the sensor with a Bosch, reset it, and the code came back on in 20 miles. Had another shop check it out and they replaced that sensor with an NTK sensor. Done a couple hundred miles since and the code hasn't returned. Wish I'd know this info prior, would have saved myself some money .
fernandomvy
Australia
Tks for the replies guys!
But its the sensor itself that is bad or something else could be wrong ? Injectors or sparks for example. Before changing it inwiuld like to know if its sometingh that can be going wrong
The set diagnostic code is directly related to the bank 1 downstream O2 sensor, it's probably easier to just replace it, and see how the Jeep runs then.
If you want to pay the extra diagnostics fees, from a snap on ultra scanner, feel free to do that, but I'd do the sensor replacement first, to eliminate the code.
The jeep does like new properly OEM gapped spark plugs every 25-35k miles.
61660[/ATTACH]"]
Live data from injectors & coil packs & so much more can be tested/seen on the Snap On Ultra Scanner.
