I installed a Spartan locker today.
This is a discussion on I installed a Spartan locker today. within the KJ General Discussion forums, part of the Jeep Liberty - KJ (02 to 07) category!
I installed a Spartan lunchbox style locker today in my rear differential. The install wasn't to bad. No need to ...
Like Tree31Likes
Old 01-22-2018, 05:36 PM   #1 (permalink)
Myke's Avatar
Default I installed a Spartan locker today.
I installed a Spartan lunchbox style locker today in my rear differential. The install wasn't to bad. No need to remove the ring and pinion or the carrier. You remove the spider gears and replace them with the locker.
It took me about 2.5 hours. Mainly because the instructions didn't mention reinstalling the c clips so I had to remove it and redo it after following a YouTube video instead of the included instructions. Could do it again in hour now that I know the order.
On road it doesn't really feel too different. If you're making a tight turn you can barely hear it clicking as it allows one wheel to spin faster by a ratcheting mechanism. I didn't feel it push against me on throttle and turning. Really went into it expecting it to not drive as well and I now wish I did it sooner.
Offroad it made a huge difference. I walked right up hills I struggled with before. Can do so much more in 2wd now. Even driving on the slick surfaces, many mud covered roads, it didn't try to push against me when steering.
Probably one of the least expensive ways besides Lincoln locking. Will let everyone know if I end up breaking it.
u2slow, Kj/toy, profdlp and 5 others like this.
DobermanRacing.com - Team Driver
  • '03 KJ Freedom Edition - 4" JBA Coilover Lift w/ 32" Cooper STT PROs
  • '98 XJ Sport - 6" Full-Traction 4-Link Long Arm - Jeepspeed #2731 (Race Jeep)
Sponsored by UltRanger & CellTech
Myke is offline   Reply With Quote
Old 01-22-2018, 05:59 PM   #2 (permalink)
ltd02's Avatar
Supporting Member
I'm intrigued. Not planning on taking mine off road any time soon but I really liked the trac-loc I had in the 02 for day to day use. There were some slippery times when I benefited from it without needing 4wd. I know the trac-loc wasn't robust for you off-roaders but maybe this is an alternative for me too?
Kj/toy likes this.
02blue reincarnated.
2005 Limited STS(61k) 242/42rle/recall hitch/CrossContact 235-65-17/Bright Silver Metallic and shiny plastic covered wheels
2002 Limited (179k) "GONE"
"...if it is a Miracle, any sort of evidence will answer, but if it is a Fact, proof is necessary…." Mark Twain
"There was a time that the pieces fit, but I watched them fall away." -Tool
"To live without Hope is to Cease to live." -Dostoevsky
ltd02 is offline   Reply With Quote
Old 01-22-2018, 07:10 PM   #3 (permalink)
CzarKJ's Avatar
A true-trac would be a better version of the trac-loc if you were considering it. Love it personally. Made my rear tires feel much more firm. Wish I had one in front as well.
ltd02 likes this.
"Lady" -03' Sport Patriot Pearl Blue
CB Radio/Firestick antenna
03' Renegade wheels, General Grabber AT2 Tires 245/70/16
MBRP Performance Exhaust, Rear Detroit TrueTrac, Fastman Throttle body
Armor: Mopar Front, TCase/4XGuard Trans, Rock Sliders/Skid Row gas tank, Solid Works Differential Armor
Ironman/Bilstein 2" lift
Yes, it's a stick.
CzarKJ is offline   Reply With Quote
Old 01-22-2018, 08:12 PM   #4 (permalink)
ltd02's Avatar
Supporting Member
I did look at the truetrac right after getting the 05 but almost twice the cost of the spartan. Probably would be the better choice for my needs though. Gotta do some suspension work before I worry about that big of an investment.
Edit: How about the Powertrax? I see they fall somewhere in between.
Old 01-22-2018, 10:11 PM   #5 (permalink)
dude1116's Avatar
Powertrax, Aussie, and Spartan are all lunchboxes. Supposedly not ideal for every day use due to their tendency to lock up at unexpected and non-ideal times but good to use on the trail.
ltd02 likes this.
'04 Silver KJ
-OME927 springs/90009 shocks, 3/8 inches of top plate, conduits, and JBA UCAs in the front. JBA 4" springs/Monroe Load Levelers in the rear.
-LT265/70/16 Hankook Dynapro ATM, Load Range D2
-Magnaflow Muffler
-Sport 4x4 Hood Decal, Graphite Jeep Hood Emblem (Woo!)
-Altezza Tail Lights, all LED bulbs and load resistors, LED third tail light
-IRO UCA w/ Iron Forge Customs bracket
dude1116 is offline   Reply With Quote
Old 01-22-2018, 10:46 PM   #6 (permalink)
I’m also wanting to put one in my Jeep after I did a lot of research on them. They seem to be the best option for someone on a budget.
ltd02 and Myke like this.
Kaden is offline   Reply With Quote
Old 01-23-2018, 02:47 AM   #7 (permalink)
Myke's Avatar
Powertrax has a few different versions. They have one just like the Spartan that is a lunchbox locker and they have one that is like a limited slip. I would do your research between Powertrax vs Spartan Aussie. I went with Spartan because it came with a hardened cross pin and was supposed to be stronger.
ltd02 likes this.
Old 01-23-2018, 07:48 AM   #8 (permalink)
ltd02's Avatar
Supporting Member
I now see the lunchbox locker version but I was looking at the Powertrax LS version. I might try one in my truck first. I don't drive it as much. Probably stick with the LS version no matter what. Need to read more reviews since not sure its worth saving a couple hundred if I'm not happy with it. I know the Truetracs are very good.
Thanks everyone!
Old 01-23-2018, 07:58 AM   #9 (permalink)
Interesting... I'm intrigued as to how this unit holds up for every day drivability...
So about $300 for each axle is what I'm seeing, sound about right?
Old 01-23-2018, 08:56 AM   #10 (permalink)
tjkj2002's Avatar
You don't want one up front since you can not "unlock" the front drive line,plus you will have to remove the front diff and pull the carrier to put one in on the D30A since it uses a spring pin to hold the spider gears in place(cross pin) which is blocked by the ring gear(so that must be removed to get the pin out).
Just remember using a lunchbox locker still leaves the same problem as open(or factory LSD),a week stock carrier.The stock spider gears are 100 times stronger then the cast carrier.
JasonJ likes this.
