jeeptorino68
been wanting to do this for a while, and finally did because one of the mounting tabs on my 2002 silencer box broke.
so here goes:
parts required:
1x: K&N 084034 (3-1/4 to 2-3/4 silicone intake coupler)
2x: 1/4" NPT x 5/8 hose barb fitting (brass)
1x: 1/4" NPT elbow (brass)
1x: 1/4" NPT short nipple (brass)
04+ KJ intake tube
31/64 drill bit
get a 04+ intake tube, from the airbox to the throttle body.
-on the throttle body side of the intake tube, cut off the softer flexible rubber part, this houses the IAT sensor.
-clean up the cut, no loose plastic shavings.
-drill a 31/64 hole in the tube on the right for one of the vent hoses, thread in a 1/4" npt x 5/8 hose barb. the metal fitting will cut threads in the plastic
-drill another 31/64 hole just behind the "3" that is embossed on the intake tube (see pics)
-assemble short nipple, elbow, and remaining 1/4npt x 5/8 hose barb, then thread this assembly into the hole, barb should point to the passenger side.
-connect all the hoses and coupler and you are done
i like the look a lot better than the 02/03 silencer box (resonator), and this is smoother. gas mileage? maybe...
maybe another time i will find a way to get the iat into the tube and off the manifold
enjoy
so here goes:
parts required:
04+ KJ intake tube
31/64 drill bit
enjoy
