Hello again.
In search of fixing the intermittent misfire and associated code, I purchased the Cam Sensor and Crank Sensor upon recommendation here. I ordered Mopar, of course. I've already installed the Cam Sensor, it was a breeze.
I went to install the Crank Sensor next, it didn't go as well. For the most part, everything went fine. I unclipped the harness, and removed the bolt holding it in place. After this, I couldn't get the Sensor to come out. I don't know if it just takes more force and I just need to manhandle it out or if there was some trick with getting it out. I didn't want to force it and break anything so I figured I would ask the experts. Please let me know if there is some special key to getting the sensor out, or if I just need to give it another try with more force.
Thanks!
Thanks!
