Drive train ticking
This is a discussion on Drive train ticking within the KJ General Discussion forums, part of the Jeep Liberty - KJ (02 to 07) category!
My KJ has a tick somewhere in the front, I believe from the drive train. It does increase with speed ...
Old 09-12-2018, 01:36 PM   #1 (permalink)
Default Drive train ticking
My KJ has a tick somewhere in the front, I believe from the drive train. It does increase with speed but goes away when I shift into neutral, which explains why I never heard it while manually reving the engine at the TB.
Besides checking the driveshafts, is there anything else I should suspect?
2004 KJ
3.7L AT 4x4
red450 is offline   Reply With Quote
Old 09-12-2018, 09:02 PM   #2 (permalink)
ltd02's Avatar
Supporting Member
Besides the front driveshaft (especially the recessed CV at the Tcase end). I'd check the CVs on the front axle shafts too. Does it change with turning?
02blue reincarnated.
2005 Limited STS(67k) 242/42rle/recall hitch/CrossContact 235-65-17/Bright Silver Metallic and shiny plastic covered wheels
2002 Limited (179k) "GONE"
"...if it is a Miracle, any sort of evidence will answer, but if it is a Fact, proof is necessary…." Mark Twain
"There was a time that the pieces fit, but I watched them fall away." -Tool
"To live without Hope is to Cease to live." -Dostoevsky
ltd02 is offline   Reply With Quote
Old 09-13-2018, 07:46 AM   #3 (permalink)
No change with turning and no clunking or popping from the CVs when turning.
I checked the front and rear driveshafts, no play in them. However, I did notice
a leak at the pinion seal on the front diff. But no spots on my driveway, so either it isn't that bad or maybe only leaking at speed? I'll add that to the fix list.
I guess Jeep still stands for Just Empty Every Pocket.
Old 09-13-2018, 04:52 PM   #4 (permalink)
Unless you're in 4WD, the front driveline doesn't care if you're in neutral or not. Does it change when you get on or off the throttle?
TomB985 is offline   Reply With Quote
Old 09-13-2018, 04:59 PM   #5 (permalink)
I think it's an exhaust leak. More Googling turned up similar threads on other forums.
Old 09-14-2018, 04:02 PM   #6 (permalink)
Does it sound like it's coming from behind the dash? If so, check the connection of the exhaust downpipes to the exhaust manifolds.
Mine had some small leaks there a while ago. It took me forever to track it down... after I took pretty much the entire dash apart trying to find the source of the noise .
Royy is online now   Reply With Quote
Old 09-14-2018, 09:04 PM   #7 (permalink)
It sounds more like it's under my feet. I know there is a leak near the muffler as well. I think it's time to just replace the whole system.
Old 09-16-2018, 02:52 AM   #8 (permalink)
LibertyTC's Avatar
Ah Ya... $$
Mine is on ignore, the valve ticking/ exhaust manifold leak I believe.. $$
Need A Push?
LibertyTC is online now   Reply With Quote
Old 09-17-2018, 08:14 AM   #9 (permalink)
It was chilly this morning, so with the windows up, it does kind of sound like it's in the dash. I'll check that connection whenever I get around to changing the 02 sensors. Thx for the tip!
