Does air con run full time, always clicks.
atvuornf
Bristol UK
As soon as I start my car and the engine fires up I head an immediate click of the air con compressor clutch even though it's not turned on. If I look down it's engaged.
Should this be so or do I have a stuck relay/switch?
rjkj2005
US
Yes. Except on recycle and fresh air vent. Untill you push the AC switch. It runs on blend(vent and floor) heat and defrost. This is so it can take out moisture from the cabin. And yes it will cycle when you first start the vehicle to test the system.
atvuornf
Bristol UK
Thanks, the more research I do seems to confirm that the compressor does indeed run when you don't want it to. There is no override, it's all pre-programmed.
The only good thing is that my system is how it's meant to be.
adamkrz
New Britain,CT
I think it applies to 2005 + years, My 04 does not cycle. Only in defrost or a/c mode..
Jeremy-WI
Home
I pulled the relay on mine, hate that luke warm air for defrosting the windshield
JeepJeepster
Dem hollers in Ky
You can take the hvac controls apart and fix this. Ive got the 05+ hvac controls in my 04 and the only time the a/c runs is in pure defrost or when I turn it on.
Otherwise it will run in the floor position, mixed floor/defrost, and defrost modes. Huge waste....
