DIY transmission flush?
This is a discussion on DIY transmission flush? within the KJ General Discussion forums, part of the Jeep Liberty - KJ (02 to 07) category!
I have a ton of BG Automatic Transmission clean and I am due for transmission fluid and filter replacement. If ...
Like Tree8Likes
Old 05-14-2018, 09:54 AM   #1 (permalink)
Default DIY transmission flush?
I have a ton of BG Automatic Transmission clean and I am due for transmission fluid and filter replacement. If possible i would like to do the fluid flush myself. I do not have a flush machine, but if I disconnect the return line on the transmission cooler and feed the transmission fluid to cycle through, I should be able to get all the fluid changed.
Does anyone here do this? the reason I am doing this instead of going to the dealership is they were charging 200 for a transmission service and they don't even change the filter.
my follow up question to this is should I use some of the BG ATC+ transmission cleaner before I change the filter and flush the system? I have had the jeep since 48,000 miles and I had the dealer do their transmission flush at 60k and 90k miles and I did the filter and what fluid was in the pan myself at 120k and replaced the factory pan with a PML pan.
thanks in advance for the help.
2006 KJ SPORT
BDS/BILSTEIN lift, homemade front shackles, matte black powdercoated TJ MOABs with 265/70R16 geolanders, rigid dually spotlights,true tracs front and rear with 4.10 gears.
soon to be added: pioneer AVH-4201NEX, back up camera, mbrp muffler and tailpipe.
cplchris is offline   Reply With Quote
Old 05-14-2018, 11:59 AM   #2 (permalink)
The dealer needs to flash the PCM into fast learning mode after changing the transmission fluid. If you do it yourself, the transmission will shift really hard for a while because of the pressure change from the new fluid.
tommudd likes this.
2007 Jeep Liberty Sport
Current- 4.7L Throttle Body, Airbox Mod, Front Tow Hooks, Engine, Transfer Case and Gas Tank Skid Plates, Falken Rubitrek A/T 235/70R16 tires
Future- 1.5-2 inch Lift, Nerf Bars
BillyG is offline   Reply With Quote
Old 05-14-2018, 12:39 PM   #3 (permalink)
rjkj2005's Avatar
Never heard of such a thing. I've changes filters and fluid in my vehicles several times. They shift the same as they did before the change.
rjkj2005 is offline   Reply With Quote
Old 05-14-2018, 02:49 PM   #4 (permalink)
sounds like fake news to me. I could see there possibly being a difference in a neglected transmission, but like I said, it's been changed every 30k miles.
2006 KJ SPORT
Old 05-14-2018, 11:29 PM   #5 (permalink)
uss2defiant's Avatar
Send a message via ICQ to uss2defiant Send a message via MSN to uss2defiant Send a message via Skype™ to uss2defiant
i DIY my ATF exchange via the dip stick.
2003 Jeep Liberty limited 3.7L V6 4x4 w/ tow package.
All stock. Yokohama Geolandar A/T-s 235/65R17 108H
45RFE, NP242, Selec-trac, Trac-Lok rear diff., ABS
~170k Miles
My KJ youtube playlist for ref. https://tinyurl.com/jeepkj
uss2defiant is offline   Reply With Quote
Old 05-15-2018, 12:23 AM   #6 (permalink)
tjkj2002's Avatar
It's actually listed in the service manual when changing the ATF in the trans.
Old 05-15-2018, 12:59 AM   #7 (permalink)
Anyone able to edit that info out ?
2002 Limted
Front-OME 90009/OME 2927
Rear-OME 132L/OME 2948 springs
JBA UCAs
JBA .25" top plates and .25" rings
245-70-16 Cooper AT3s
Aceofspades is offline   Reply With Quote
Old 05-15-2018, 08:32 AM   #8 (permalink)
not in the 2006 service manual, maybe that was just standard procedure for the 02-04 KJ. Also, the FSM says to only use mopar ATF+4 approved fluid. the jeep dealer i was going to for service was using BG ATF, which i am sure is great stuff but it isn't MOPAR ATF+4 approved AFAIK. so if they weren't bothering to use the right fluid, I doubt that they would be taking enough care to flash it back into fast learn mode.
edit: it also says that a filter change should be performed at the time of fluid change, which they were also neglecting to do. they are essentially charging people $180 to do the same thing any Instant Oil Change shop would do.
2006 KJ SPORT
Old 05-15-2018, 09:52 AM   #9 (permalink)
I found an old thread that talks about having the PCM reflashed after a transmission flush, but no clear decision of what to do if you just drop the pan and change the filters.
Transmission fluid change?
Old 05-15-2018, 10:52 AM   #10 (permalink)
again, no clear answers to the original question posted in this thread.
the recommendation seems to be "take it to the dealer so it's done right"
well my dealership uses/used the wrong fluid, doesn't change the filter, and likely doesn't even think about doing a re-flash or re-learn.
then I'm seeing people say that as long as the flushes are done regularly (every 30k miles), then there isn't an absolute need for a re-learn.
so i'm thinking I will just abandon this thread, run the cleaner for 100 or so miles, change the filter, and flush the transmission myself by disconnecting the cooler return line. I'll see what i can do about the re-learn with the OTC scanner I have access to.
2006 KJ SPORT
