2003jeepKJ
I took the 2003 Liberty Sport in for the airbag computer recall, it took over a year for them to get the part. Anyway, I told the Service man to check the suspension, it wonders. It seems when I leave off the gas the car does a very slight jerk. Sometimes it will do this when cruising during highway driving.
It feels like when you hit uneven pavement.
This problem is happening in 2 wheel drive.
The Tech said that I have to replace the front drive shaft for $600.00. The sealed joint is most likely failing and causing the tension on the suspension. I found this explanation rather ridiculous. How can it cause any torque on the front, if it's not in 4 wheel drive.
What do you think?
What might be causing this little jerking feeling.
The Tech said the rest of the suspension is good.
Thanks for your help!
What do you think?
