Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Car wouldn't start, think its the clutch safety switch that is broken. There are 4 wires on the connection. Any body know which I should bridge to prove its the switch or not?
There is another method you can use to confirm if it is the clutch safety switch. Engaging 4 Low Range overrides the clutch safety switch to start without having to depress the clutch. You can engage 4Lo and see if it starts. If it does start then its the clutch safety, if it doesn't start still then you need check the fuse and relay.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
