Jeep Liberty Forum - JeepKJ Country
Jeep Liberty Forum - JeepKJ Country (http://www.jeepkj.com/forum/)
-   KJ General Discussion (http://www.jeepkj.com/forum/f196/)
-   -   Cheap AC Bypass **PICTURE** (http://www.jeepkj.com/forum/f196/cheap-ac-bypass-%2A%2Apicture%2A%2A-45242/)
gijoe31484 06-05-2010 01:17 PM
1 Attachment(s)
Recently my AC clutch seized up on me and I figured out a new route for the serpentine belt.
If your freezes up and you can't afford to get it fixed...use these instructions on this link to get your pulley and clutch off. I didn't have the pulley puller so i used a pry bar, hammer, a bit leverage, and lots of redbull:p.
http://www.sparkys-answers.com/2009/...mitent-ac.html
The belt you will need is a 6-rib 82.5 inch length. $28ish=D>
The attached picture shows the new route. I checked, and everything turns the right direction and I even did a 35 mile round trip right afterwards with no problems. You could probably use up to an 83.5 inch length because my tensioner pulley is at about 75% capacity....it should stretch out a little bit though. =D>
family KJ 06-05-2010 05:29 PM
Been there and done that! Lasted about 2 years until I got money to get it repaired
jnaut 06-05-2010 10:24 PM
Thanks GI joe. Bookmarked this thread. Always helps to have a picture.
TAwesome 06-06-2010 01:42 AM
Nice!!!!
azmotoman 06-06-2010 05:40 AM
This would be a good time to buy a spare and be ready for the 'boonie breakdown'.
Is there a Gates P/N?
deadstar717 06-07-2011 04:00 PM
GIJoe,
I see that this post is a year old, but the AC Comp just seized up on my '02 Liberty 2WD Sport. I just want to be sure on the belt size... it sounds like 82.5" worked for you, but was your Liberty an '02?
Thanks,
David
Akedos 06-07-2011 08:51 PM
Exact same thing I did here, even the same belt size iirc:
http://www.jeepkj.com/forum/f196/ac-compressor-bypass-40044/
ridenby 06-08-2011 12:17 AM
I am using a duralast 827K6.
simond 06-08-2011 05:01 AM
nice hint... will consider thaht when the ac's gonna die!
Sparky1187 06-09-2011 09:44 PM
Were there any special tools required to remove the pulley from the compressor?
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Search Engine Optimization by vBSEO
Ad Management by RedTyger
