TwoBobsKJ
So I go to open the rear gate this morning and the latch that holds the rear glass closed wouldn't release. What the....?
After messing around with things for a while I figured out that the lift glass button on the key fob will release the rear glass but the switch inside the gate that releases the lift glass is dead. So the good news is the motor that controls the latch is fine but that little switch is dead.
That switch can be removed from the handle on the rear gate and then disconnected from the wire harness. Problem is I can't find a part number for that little switch (it's just a small momentary switch that is tripped when the gate handle is pulled.) Anyone have a source for those types of switches and the harness? I've tried all the Mopar online sites I know of, and the descriptions on RockAuto don't give me confidence that I'd be ordering the right one.
I may end up pulling a switch from a wrecked Libby if I can't find a new one but I'm worried that the donor switch will be corroded and fail just like mine did.
What say all you electrical gurus? :cheers:
