Hello yall. I am getting P0344 and P0016 codes on my 04 Jeep liberty with 3.7l engine. Have checked out wiring and all looks good. Also replaced the position
sensor to no avail. I am aware that the timing chain may have a bit of play but I don't feel enough to be causing issues with this. I have recently replaced the RH head and gaskets. Any ideas what may be the cause. Would like to try to tackle cheap things first then work my way up to the timing if that is indeed the issue. With both of these codes I figure they may have something in common that relates to both codes. Any help greatly appreciated. Thanks
