A/C problem
rigid
united states
when I switch the control to A/C the air does not change to cold . The clutch on the compressor does not seem to engage . I checked the fuse under the hood . I also switched the relay that controls the a/c clutch with the hi/lo wiper relay . Is this as bad as I think ? compressor
Thank you
Rowlette
Florida
I would first try adding some freon??? R22?? Before considering a bad compressor.
Laughing at oneself and with others is good for the Soul
Could be any number of things. Chances are there's a leak and the refrigerant (r134a) leaked out and there's a low pressure switch to disable the system to prevent damage. Need a 2 gauge manifold to get a good picture, don't just add stuff.
This is something that I personally think is worth taking to a shop, less expensive to get it done right.
Conundrum2006
Alabama
Simple answer is it probably low ac freon, but if it's low it's leaking.
To sort it out right, or just begin to sort it you need to get an idea of if it's got any freon.
Ac work is a PITA, if your ac line is empty then it's open somewhere and you've got a lot of repairing to do to begin to recharge it.
Or a idiot kit from Walmart might get'er done.
Depends how DIY you are. A reasonable ac shop may be the a good idea to start with.
I'm repairing the ac on our commander now, it. There was a lot of extra work that in some cases was unnecessary to trouble shoot. Didn't take it to a shop cause the commander with rear ac has several intricacies that make it hard to diagnose. I've also got the tools to vacuum and recharge ac.
rigid
united states
Daughter came home and said her liberty was blowing warm air .. since I know the history of hers I took a chance and bought the ac pro rig at Walmart. . 30 seconds and hers was fixed . Good as new . The other one I started this about is not . I hear a leak from somewhere around the driver front corner of the radiator support area . Can't feel it but leaks as quick as I pull the trigger. Any ideas?
Thank you
Conundrum2006
Alabama
Should be a condenser by the radiator, possibly a hole in one of the lines or inline dryer. Probably the condenser either rotted away or hit something to cause a leak .
On the commander dryer accumulator and lines clustered by the radiator, old XJ it was just the condenser up front.
The AC condenser is in front of the radiator.
You'll have to use a UV dye to see if there are any leaks.
Conundrum2006
Alabama
May already have UV dye from the factory.
However is it's loud enough leak he can hear it it should be a obvious whole or rotted area.
jeepop
Middle Tenneesee
If you can hear it, put some dawn in water in a spray bottle and hit the area, bubbles will show where it is. Mine leaked in the middle of the compressor body.
