96superjet
my wife has an 04 liberty 3.7l. last thursday she said she hit a pot hole rather hard, when she got home she could smell antifreeze and it was bubbling out the back of the resevoir. the heater quit blowing hot air, i have concerns that the coolant isnt circulating properly but waterpump isnt making noises or leaking, i put new coolant to the cold fill line, i started it opened up the bleeder screw, one time there was coolant coming out of it and the other time i tried was just steam. ive done some research on it so i went and purchased a engine block leak tester(chemical test) first try it turned yellow, is this a 100% sure sign there is a blown head gasket. there is a small hairline crack in top of radiator is it possible its getting air into the system this way, or sucking exhaust fumes. and if it is a blown head gasket is it driveable till i can get the new gasket and special tools to do it. thanks in advance.
