This has been going on for several years and I just deal with it however I just spent a ton on a new engine so I'm in the mood to get everything working right.
A/C on outside air blows like mad through the vents. When you put it on recirculating air 90% of the air is dumped into the dash, not the defrost, floor or vents, it just disappears into the dash.
Could the actual A/C-Heater control box be bad? I have tried the right/left/right/left re-calibrate trick but it does nothing and I understand that is the case with the 02, the trick works on 03 and up.
