I have a 2003 liberty Sport with the 2.4, if that makes a difference. I believe the clutch is worn, as the ac will work for an uncertain amount of time then fade out and back in some of the time. Usually after it quits it doesn't come back until it has cooled off. If I run it till it quits, you can see the clutch move in and out when someone switches the ac on and off, and if you tap it with the ball of the hitch, it will engage with the hitch magnetically attached . I got the bolt off of the clutch, but how do you remove the clutch. The factory manual does not mention any special tool for removal and just says "remove the clutch plate".
