2003 KJ, loose upper control arm bolts?
DallanC
Utah
Greetings folks, new here. I found this site after researching knocking noises in Liberty Suspensions. Some good info here on tracking down problems and causes, but I've run into something different.
My boy has a '03 Liberty and has been driving it for about a year and a half. It developed a pretty nasty rattle in the front end you could feel through the floorboards on the driver side. I checked all the usual suspects, and all joints and bushings appeared nice and tight.
What I did notice however, is the upper control arm on the drivers side seemed to be loose where it bolts to the body. It seemed to move about 1/8th of an inch when I pushed / pulled on the tire and it did made a loud noise. We tore into it a bit, removing the battery mount to get at the bolts and the rear upper control arm bolt felt loose when I got a socket on it. I tightened it thinking that would solve it.
My boy drove it for a day and said it sounded worse. So, not knowing the state of things, and with upper control arms being moderately cheap, I ordered one and we swapped it out today.
With everything disassembled, the old upper control arm seemed in fine shape, but we still tossed in the new one. I inspected the bolts for wear and did not see any. I tried putting the bolts into the mount holes without the UCA in, to check for slop... and they did feel loose. Its hard to get a look in there but it felt like either there is alot of slop in the tolerance of the bolt to mount, or its worn against the mount and worn it / elongated the bolt holes.
So thats my question... how tight are the Upper Control Arm bolt supposed to fit in the mount holes? Has anyone experienced this? I cranked it down pretty darn tight with a 24" breaker bar and a 12" extension. I dunno if the bolt can get tightened down enough it stops the UCA from shifting around on big bump and potholes. I would expect alot of wear on the bolt itself if its been wearing against the mount.
We drove it a bit after the UCA replacement and its still knocking but not as much.
If the bolt hole has rounded out / worn... IDK quite how to fix it. Its pretty tight space to work, I possibly could weld a couple washers to the mount ... but then I worry about rust and other issues down the road.
Any experts here have 2 cents of advice? Thanks in advance :)
-DallanC
Jbergun
Chicago
You would have to bend the body to get it to press against the uca. I just did mine and didnt check for any play. There is a rubber bushing in the new uca i had to use a drift pin to get the bolt through. I had a knock replaced both arms and its gone. You have to get an alignment after.
RenKJ
Canada
Did the bolts in your bushings for uca look somewhat like this one with a tab welded to the back end? It should have a lip like the one in the picture and the tab would be on the same side as the lip unlike the picture.
Sent from my SM-N910W8 using Tapatalk
Did you torque it with the full weight of the Jeep on the ground? They can make noises and fail early if they get torqued before having the full weight on the ground.
DallanC
Utah
Thanks for the replies,
Yep I torqued it down with the full weight of the vehicle on the arms. I do plan to get it aligned but not until we track down / solve the issue. My kid only drives it a short distance each day to school and work. If any tire wear becomes apparent we can do the redneck alignment method to get us by. I'm thinking an 1/8th inch movement in the anchor point is enough to throw alignment out the window anyway.
As for the bolt itself, I wondered if it had the correct bolts and what it has exactly matches this one, so I think its correct:
https://www.ebay.com/itm/02-03-04-0...iberty&hash=item2cd30ff57b:g:AAsAAOSwvg9XfXHz
I could always weld the bolt to the mount... and let the next guy worry about fixing the UCA... /evil laugh
-DallanC
Could be many things.
Now if its been loose for a long time ( the upper control arm ) it could of wallowed it out some , but I doubt. Pretty thick right there. Have torn into over 55 of them and never had a issue like you are describing .
What I would be looking at for the noise is the sway bar links, the bushings for the clevis where it attaches to the lower control arm. Also a blown shock can create such a noise. How many miles and how sagged is the suspension. ( measure from middle of the wheel to bottom of the flare )
Give us some more info please
DallanC
Utah
Sure thing, thanks.
The jeep has 178,000 miles. We've owned it for a year and a half, everything was fine until about a week ago (according to my boy). He doesnt off road at all... and its not been on very many dirt roads (to my dismay anyway, i keep telling him its a jeep, go 'wheeling kid! :gr_grin:)
Its raining like crazy right now so being the smart dad, I sent my boy out with a tape to measure sag. Left is 20 1/4" and right is 19 3/8"
Like I said, I did put the bolt through the holes without the UCA and moved it around and it seemed quite loose. I would have expected noticeable wear on the bolt though if its been wallowing out the mounting hole, but they looked fine. Thats not to say the previous owner didn't replace them however.
Blown shock I agree could cause rattle, I'll have to look into that closer. Swaybar link bushings I could see some minor cracking of the rubble but no movement and nothing that looked like metal on metal contact.
When we drive it you can feel harsh contact of metal colliding through the floorboards... and with the rear UCA attachment point right there, and seeing movement, that was my guess to the cause.
We'll keep poking around. I should have pressed some sillypuddy into the holes, removed and looked at the wear pattern. I think I could run a weld into the back of the holes from inside the wheelwell to close it up some, then dremel off each face to square it up, then re-drill with the appropriate sized bits (bolt appears to have two sizes, threaded area and thicker near the bolt head). Then shoot it with some Krylon for rush prevention and bolt it all back up. Trying to square up any weld material on the far side of the rear UCA mount under the master cylinder will be a pita for sure.
Maybe tomorrow after work with a break in the rain we'll jack up the tire and see if we cant move something with a prybar that gives a better indication of whats wrong.
I am not a mechanic by trade, but have above average skills and tools to fabricate and work on stuff.
-DallanC
I'd say blown shock too. Perhaps coupled with a shot mount.
Every time I've had a blown shock it's sent a bone jarring thump through the floor and seats when going over bumps.
DallanC
Utah
Alright, we'll R&R the shocks next and inspect bushings, mount etc. Thanks. I'll post results after we get that done.
-DallanC
-DallanC
I've had them in to my place with 100,000 miles less than yours, with springs done worn out and shocks blown ( many of them )
And people complaining of similar noises
Now onto your measurements , confused as stock is 19, and unless someone replaced shocks and springs recently and did a clevis lift no way to be that height
Does it have any type of spacer lift ?
DallanC
Utah
I didn't notice any spacer lift on the coils when I was under it... but it does seem to sit fairly high. It has 245/70R16 tires on it.
Here's a picture of it:
I have replacement springs/bushings/mount combo on order, should be here Friday. Now I'm worried maybe it had special lifted springs or something and what I ordered wont work. Hmmmmm
-DallanC
245-70-16s will work with normal height springs, well depending what you ordered.
Bet there is a spacer lift or some other cheap springs like Skyjacker, Rustys etc
DallanC
Utah
I snapped a picture of the spring / shock assembly... Is that a lift spacer at the bottom of the spring? Is there any identifying marks on a OEM spring?
-DallanC
Spacer....holy crap is that thing stacked. Bet you're getting some coil contact over bumps. That thing has to ride awfully.
:shakehead: Not a good way to solve sagged out springs!
DallanC
Utah
LOL... to be clear, I did not do this. Bought it that way, it is for my highschool boy... It rides ok around town, I dont doubt the coils are hitting on big bumps... but he doesnt off road so it shouldnt happen too much.
But the spring sag comment brings up a good point. I'll have to break down the strut to get the spacer off... I should use the old spring too to keep it at the same ride height as the others. Going to be a pita finding a tool that can fit between the coils. Going to be a mighty interesting weekend.
-DallanC
You should get a new springs. It will ride so much better, and alignment will also have to be done.
Looks like the rear is also lifted a bit & when you remove the spacer up front...
How high will the rear remain then?
What are the current measurements from the center of wheel/ jeep cap to beginning of where fender begins inside? Front & rear in inches?
-DallanC
Not to be a jerk, BUT that thing rides like total crap no matter on or off road. Sorry just the way it is. The old springs are not worth anything at all, they are stacked, meaning its coil on coil going down the road. I have 12-15 pairs just like that laying around .
DO NOT try and use any of those cheap spring compressors, take them to a shop, AFTER you buy new springs and shocks . The way those are I wouldn't let my son even drive it. I've done over 55 KJ lifts and that has to be ALMOST the worst I've seen. NOT the worst but close to it. If you remove that spacer then you'll be at 17-17.5 inches way below stock height
Damotee
Cape York, Australia
Wow those are some seriously compressed springs! I wouldn't be taking that anywhere near an off road track (not that your lad goes off road, but still, its a Jeep!)
Even cornering would be rough with those springs, id imagine?
