"Secure Console" for XK, HK & WK
Arizona XK
Sunny Arizona
I just had this product custom made for my Commander and thought I would share it over here in case other members with Commanders or Grand Cherokee's were interested.
Link to "Secure Console" on JeepCommander.com
If this is not allowed please delete, but this is a great product (The link will take you to the install in my Jeep) and there are not a lot of people making aftermarket for these vehicles so we need to share with each other.
I am the Super Moderator over at JeepCommander.com so you can check references if you are concerned bout a newbie selling stuff.
Arizona XK
Sunny Arizona
This project has been 4 months in the making but there is finally a finished production model of the "Secure Console" That is available only here at JeepCommander.com
As many of you know while attending SEMA this past November I saw many great products for the Commander and talked to many different companies about producing products for the Commander. One product a saw was a lockable storage unit for securing your valuables inside your vehicle. At the current time there was nobody making such a device for the Jeep Commander so I asked one firm about producing such an item for us.
I shipped my spare center console to them and they worked up a product that I feel is a great modification to our current center console, The "Secure Console" as I have named it is not a lockable box like other companies manufacture but is instead a lockable door to attach to our existing center console. The "Secure Console" was custom designed, engineered and manufactured for us by a major safe company right here in the United States.
The "Secure Console" takes less then five minutes to install and will provide more then enough security to keep your valuables where you left them. There are no modifications that you need to make to your Commander and you can remove it at anytime without leaving any indications that it was ever installed (as long as you leave out one step in the install process).
The "Secure Console" is ONLY available here for our forum members and can only be purchased in a group buy program. The cost to manufacture these on an individual basis is cost prohibitive for the manufacturer so they will not stock this item and will not sell it through their distribution channels. That is actually good news for us because by eliminating the middle man we can keep the costs down to a minimum. And the more we order the cheaper the cost.
As you can see in the three photos above, this item has been custom made to match the lines of our console and is make of a high quality think steel that has then been powder coated black for a very professional look. The lock has a three number combination that you are able to change as needed. The unit can be left in the unlocked position when you are not storing valuables and with a quick turn of the knob you can lock the top in place.
Arizona XK
Sunny Arizona
Here is a quick look at the unit prior to install, You would receive your item exactly like the one in the photograph.
And this is what the back/underside of the unit looks like:
On the underside you can see the tab (to the right as you are looking at it) that slides into the front of the center console to position this unit and hold it in place, you can also see three attached bolts that you attach a backing plate to with the nuts that are provided to prevent the unit from being lifted out by anyone else.
The outer appearance of your center console will not change at all by the installation of the "Secure Console", They only one who will know it is there is you.
You will also notice that the opening is the same size as the current opening so this unit does not take up any of you inside storage space.
The installed unit has a clean professional, high quality look to it which is what you expect when you are installing it in a $40,000 vehicle.
Arizona XK
Sunny Arizona
Drop the tab in under the front edge
And let the back end drop into place.
If you used a adhesive/sealant then follow those instruction as to applying pressure or resting time before continuing with these instructions.
When you are ready to continue with the install open the lid.
Line up the support brace, it can only go in one direction.
Slide the brace over the three small bolts.
And start to attach the three nuts.
Once all three nuts are in place tighten them up.
That is all there is too it.
Throw your gun, wallet whatever in there and lock the "Secure Console"
The "Secure Console" as seen in this thread is now available for purchase.
We need a minimum order of 25 unit in order to have this item produced for us. It will only be available at JeepCommander.com, you will not be able to buy it from any other source.
The cost of the unit for an order of 25 pieces will run $165.00 per unit and all 25 units will need to be paid for prior to production.
If you want one let me know in the thread and in the attached poll and when there is enough interest I will contact you for confirmation, payment and place the order.
